Question about no Transmission fluid
I noticed that my eng. was making a noise that sounds like a car belt that squeaks or whistles when its idling. I checked the gaskets on the pipes, it started to notice it about 60 miles ago. Everything looked OK until I checked the Transmission oil. Nothing on the stick. Nothing after cleaning it when I screw it in or at rest on the threads. There was a bit of oil on the stick when I first took it out so I assume there is some in the case. I have been getting a small amount of oil on the floor after a ride. But I thought this was from the oil filter that was seeping just a small amount of oil. I tightened the filter and it seemed to stop or at least slow down. I get maybe three drops on the floor after a 60 mile ride. Any suggestions of what to look for appreciated. Thanks in advance.
First things is to put some gear oil in the trans while you figure out what you are going to do. Plenty of help on the forum; I have done the repair several times myself as have others.
Thanks I appreciate it. I have a clymer manual. What Oil do I put in while I figure it out? I have a bottle of 70-90 gear oil. Its not syn. but if its only for a bit till I get the fix done. Also do you have any links to any videos on how to do it so I can get a visual I would appreciate it a lot. thanks for the reply.
if you have a squeal in your trans from a lack of oil, the transmission is toasted. the only thing that will cause that sound besides a slipping rubber belt, is bearings being forced to spin dry, it gaulds up the bearing and the shafts spinning in them. same thing as a spun bearing in an engine. the leak is from a leaking seal or possibly the drain plug isn't sealed rite. adding oil might quiet the trans down, if the damage wasn't too bad, it might get by. if you notice any other noises,or sloppiness in the trans or shifting you should have the trans rebuilt or replaced before a lot more damage occurs..
the first thing i would do is drain the oil from the trans to see how much is actually in there. there could be plenty but just not enough to register on the dipstick. look at the oil that comes out real good for any steel or brass shavings
i cant think of anything on a HD that would squeal with out meaning major internal damage.. make sure that there isn't something stuck along side the tire, that could mimic a belt.
I would get the oil thing figured out first ,I would allso get the rear tire up off the ground and spin it and look at your belt.Make sure it is tracking (belt) even on the rear pulley.Sometimes the belt will slide to 1 side and geive a noise if it is not adjusted correctly.Allso check your belt tension when it is on the ground.
A trans can survive on 20oz 's of oil so you are good there. You should always check it in the upright position. If you use a Spectro 75w140 or a Redline trans fluid they are red in color and will help you determine if you are truly leaking trans fluid as opposed to using a gear lube which can take on the appearance of motor oil and make it hard to tell. DO NOT USE MOTOR OIL IN YOUR TRANSMISSION, they are not designed to protect your gears and have detergents in them that you do not need in a transmission.
If you don't see any oil on the pan, I doubt if the leak was from the trans. Ride it and monitor engine oil level and look for drips and leaks. You also made reference to an oil cooler. It is not unusual for those adapters to loosen up and start leaking if they weren't installed properly and/or didn't use the anti-rotation device.
