need a little help please
ok ok im new to this but I have a question, i am riding a s&s 115cubed harley and it has a little valve tappet noise, Everything that I have read says that the tappets are hyd and need no adjustment, Is that true ? and also is that true with the s&s engine?
Thank you
Thank you
Welcome to the Harley world. Valve train noise is a constant source of irritation and discussion on every H-D forum you can find. What is irritating to some is not to others. Suggest you post this on the Engine/Fuel/Intake/Exhaust section; you posted in the wrong spot. First question you will be asked is what lifters and pushrods?
Or learn how to do it yourself so you don't have to rely on someone else for a very simple procedure.
