6 speed trans trouble
I have a 2007 Ultra Classic with 56,000 miles. I was riding along at 75 MPH. There was no niose or warning. The bike began to slow. The motor was running fine, tried shifting gears, no gears. towed bike to local dealer in Phoenix. They tore into it and told me the main shaft in the tranny was bad. The splines on the end of the shaft were stripped. Bottom line is it will cost me 2 grand for repairs. Is the main shaft an inherit problem with the 6 speeds?
Seen a few post in the last few years on here. There are some small double row of needle bearings that a hunk of medal from a bad shift could easily get in there an lock them up and once they start sliding rather then rolling they fail. Lot of riders put way too thick oil in the transmission thinking they need to protect it but in my opinion may be the wrong thing to do. Also when Harley stuck the extra gear row in I think case is same width as a 5 and gears and bearings are narrow. One reason why you see both straight (stronger) and helical cut gears. The helical are quiter but need extra side thrust protection and there was not enough room. Not sure why it would cost $2000 to replace transmission. Ouch. Just my opinion and not an expert. Just really wanted to sign on to see what turns up
6 speed trouble
Ripsaw,
Thanks for the quick reply. I have the bike serviced according to Harleys schedule. I have run SYN3 from day one. The dealer told me the parts for the repair were 1,000 and then 7 hours labor at $90 per hour, plus tax, total near 2 grand. At one time I would fix it myself but I am well past 60 years old now and can't do as much as I use to.
Ripsaw,
7 HOURS TO REBUILD A TRANNY OUCH!!!!!!!! I am a certified Harley tech and the flat rate for tranny is 4.6 all my tranny rebuilds are flat 250 but im no where near you anymore lol... but state that there own flat rate book which I can load pdf for you is 4.6 that you want to talk to the service manager.
MODELS Unless otherwise specified, Job Times shown include all
operations necessary to complete the listed job.
Table 5-5. Transmission
ITEM DESCRIPTION
MODELS LABOR
FMW FHW/FTW CODE
TRANSMISSION CASE
Replace transmission case 5.3 5.3 4304
Replace transmission complete 4.9 4.9 4305
Overhaul transmission includes disassembly, cleaning, inspection,
replacing parts (transmission case in
frame), assembly
4.6 4.6 4306
Replace transmission sprocket 2.2 2.2 4309
Replace main drive gear oil seal in transmission case 2.3 2.3 4311
Replace mainshaft oil seal in main drive gear 2.2 2.2 4316
Replace side door gasket 2.8 2.8 4321
Replace shifter drum 0.7 0.7 4331
Replace shifter arm assembly or springs 3.0 3.0 4336
Replace transmission top cover and/or gasket 0.6 0.6 4341
Replace shifter forks and/or shaft 1.8 1.8 4343
Replace side door bearing one 3.0 3.0 4348
both 3.1 3.1 4351
Replace transmission case countershaft bearing 2.9 2.9 4361
Replace main drive gear and/or bearing 3.2 3.2 4366
Replace transmission side cover gasket 0.9 0.9 4368
Replace oil pan and/or gasket or baffle Removal of rear wheel may be necessary 0.9 0.9 4378
Replace oil fill tube and/or cover, and/or gasket 0.4 0.4 4379
Replace transmission shifter shaft seal 2.2 2.2 4390
I can email you the pdf of all flat rate jobs just pm your email I cant post it on here yet cause of the rules
Wildpig, guess that blows my too thick oil theory for flushing those small needle bearings if they are what went. Was it the small double row needle ones that the input shaft rides on or the one the mainshaft rides in? Another thing I have not figured out is how you could tear the spline up on the mainshaft? If it took the spline out does the $1000 of parts include the belt drive pulley? But how bought a real live Harley tech on here that's huge, has a huge gun and a bike named sally. Now here is someone (2 Tall) we can learn something from.
in the later touring models it seems to be more lately 10 and up but as Harley says its the rider lol...no its cost cutting plain and simple they are cutting corners and there product and customers are starting to see that. I myself have only rebuilt 5 6 speeds from customers through dealership but I have done several baker change overs at home.
Trans trouble
tranny problem
