Sportster stuck in gear
My '86 4 speed Sportster is stuck in 2nd gear, gear lever locked solid. I can't get the gearbox internals out, have removed final drive sprocket, clutch & primary and 4 bolts behind clutch, gears should pull out. Nothing is budging. I'm sure it's the selector mechanism that's failed. Any ideas?
