Clutch basket/drum with gear
I think you mean 66 teeth. But that number of teeth means you do not have stock starter gearing on your bike.
Is it an OEM clutch outer shell?
66 tooth ring gear/9 tooth pinion gear combination was used on the five speeds through 1993.
1994 and later use a 102 tooth ring gear/10 tooth pinion gear.
These combinations are available from several aftermarket companies, and an 84/10 is also available.
soft 02
09-29-2011 01:06 AM
