02 transmission noise normal.
So this is my first Harley. I know that some noises are normal so I thought I'd ask here first. When I'm cruising down the road with the bike in gear (any gear) and let off the throttle (clutch still engaged) I have some unrythemic clattering that sounds like it is comming from the right side of the bike. If I get back into the throttle any amount the noise stops. If I pull the clutch in the noise stops. It's not excessively loud but noticeable to me. The bike is an 02 soft tail. 88ci stock motor except for pipes. 11.5 k miles. Normal? Not normal?
