Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
06 FLHX Unknown Objects fall from Primary
Old 04-07-2013, 06:09 AM
texn2000's Avatar
texn2000
texn2000 is offline
Stage III
Default 06 FLHX Unknown Objects fall from Primary
Need some help here - I was changing the chaincase oil when I found metal shavings on the drain plug magnet. I pulled the primary cover and three objects fell out. I do not recognize them and can not figure out where they would go. I am not the original owner of the bike thus, unsure of previous maintenance. Attaching some pictures. There are two metal parts and one rubber bushing. 06 FLHX Unknown Objects fall from Primary-primary-objects1.jpg
06 FLHX Unknown Objects fall from Primary-primary.jpgThanks for any help here.
Old 04-07-2013, 10:17 AM
texn2000's Avatar
texn2000
texn2000 is offline
Stage III
So, I pulled the clutch plates to see if anything was missing from inside the clutch housing. I'm beginning to think that these parts are foreign. While I had the clutch plates off, I rotated the inner "splined" assembly and noticed that the outer hub (watching the chain) is warped. The chain tightens and slackens during a full 360 degree rotation. Not a lot, just noticeable.
Upon closer inspection, it seems that these "objects" have made it around the block a few times as there is damage to the clutch housing between the flywheel and chain.
So, a follow up question: do I need to panic and replace the clutch assembly? The reason I ask is because I am heading out for a 2K ride.
Thanks,
Terry
Old 04-07-2013, 10:37 AM
ajayrk's Avatar
ajayrk
ajayrk is offline
I'll take a guess. It looks like a riser bushing, bushing sleeve and a cupped washer that sits on top of the bushing.
Now, how would that get into the primary?
Old 04-07-2013, 11:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,465 Likes on 4,598 Posts
There will be some wobble between the clutch hub and the outer shell. Looks weird but normal.
The way foreign parts get into place like this is often due to working on the machine in a cluttered disorganized work area. Always cover parts that are not being worked on.
Old 04-08-2013, 03:06 AM
texn2000's Avatar
texn2000
texn2000 is offline
Stage III
Thank you ajayak and Dan for taking the time to answer my question.
Makes me kinda sick realizing that I had had such a false sense of security riding with a literal time bomb bouncing around in my primary case. If those had got locked up between the chain and sprocket - bad things could have happened.
Dan, Im glad to hear that some wobble in the clutch is normal - I was afraid that the clutch housing may have been ruined / bent. I did start it up and watched the chain - the upper chain bounces around pretty good.
Thanks again,
Terry
Old 04-08-2013, 09:13 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Looks like a tank grommet to me. Just put those anywhere. WTF
slyedog
10-28-2023 12:58 PM
Duracell
11-19-2021 04:53 PM
exactlynowhere
12-05-2015 08:37 AM
Bens05FLHPI
08-10-2012 05:22 PM
bobbed86
08-04-2012 07:06 AM
Quick Reply: 06 FLHX Unknown Objects fall from Primary
