To engine brake or not to engine brake
Received 4,614 Likes
On a fuel injected engine it can save a little gas, on carbed engines not so much but it can cool the engine since with many carbs it will be "running" rich while coasting down. I'm of the opinion that as long as you keep the rpms low, engine wear will be so negligible as to make no difference. When I have cars behind me, I'll often give the front brake a slight pull just to light the brake light to warn them I'm slowing; most American cars for over 20 years have no engine braking in high gear and can roll into you if they aren't paying attention. I also like shifting down so I know I'm in first gear when stopped, and always in a good gear if I have to escape a sudden bad situation; hard to do in 4th or 5th at 20 mph... that alone is all the argument I need for shifting down, especially in traffic; I want that engine in a good gear for the power at all speeds all the time.
I strongly recommend you find a local MSF or similar course! They will answer all your questions and train you if necessary, so you are better informed and skilled in the right techniques.
I have taken a MSF class. I wasn't asking what was safest, I was simply asking if engine braking was hard on the engine. If so, in instances where I need to come down significantly in speed for a red light and there is no one behind me, I want to do what is best for the bike. I would think brake components would be a lot cheaper that repairing engine damage or rebuilding due to wear.
Here is a good thread on engine braking. I usually engine brake. My rear tire wore out in 6500 miles. Since blipping I am getting longer wear. I also stopped practicing panic stops.
https://www.hdforums.com/forum/touring-models/699568-engine-braking-blip-or-no-blip.html
