Pre-2006 Clutch Pull
Wanting a reduced effort clutch on my '98 Road King Classic, and having the dealer tell me the reduced effort clutch kit won't fit on pre-2006 models, I bought the ramps and and new clutch cable and tried it anyway.
Parts :
Outer Ramp : 25605-00A
Inner Ramp : 25604-00A
Installed with a new standard OEM clutch cable.
Adjusted the clutch pack according to the thread here on adjusting the clutch the easy way. Adjusted the cable. The ramps were something like $12 each and the cable was $62.
Significantly reduced clutch effort.
Parts :
If those parts fit a `98, then they should fit 1987-2006 as far as 5 speeds go (all the transmissions with ball and ramp systems).
The book probably told the guy what it would fit. This stuff happens in the aftermarket too, where a catalog may say a part only fits certain years, even though it will actually fit many more model year bikes.
Good info unclecurt.
Also, it was time to replace the clutch pack so I installed Barnett kevlar friction plates (302-30-10013K) using the original steel plates with 65K, they were fine.
I re-used the stock clutch diaphragm spring thinking if I wanted to lighten the pull further I could do that as an additional step. Not necessary in my case as the reduction in effort from the new ramps and improved clutch cable did the job.
biker girl
08-07-2010 07:26 PM
