Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch adjustment
Old 04-14-2013, 08:39 AM
0204665J's Avatar
0204665J
0204665J is offline
Default Clutch adjustment
Need some help on a clutch adustment. Was following directions form the manual and was at a point after adjusting the adjuster screw and tightening the locknut bolt.
I squeesed the clutch level per the manual three times and now am turning the adjuster cable to squeese the play out. The problem is I cannot get the play out. If fact the adjuster is coming off the thread as move it away from the adjuster nut.
Can anyone help me. I tried several times to to reset and try again, but nothing seems to work.
Any advise for me. Thanks
WEATHERED59
05-13-2017 02:51 PM
0204665J
04-25-2013 10:41 AM
eviltwin69
01-02-2013 04:32 PM
Anthony8858
09-11-2009 09:05 AM
jdtest
06-25-2007 09:35 PM
Quick Reply: Clutch adjustment
