cant pull clutch in
cant pull clutch in
I installed an Ultima 6 speed gear set into my factory trans case. I removed the stock 5 speed gear set and put everything back together the same way I pulled everything out. The problem I am having now is when I try to pull the clutch lever in it is rock soild. I can not pull the lever in at all. I think there may be an issue with the push rod (s). The long push rod is def. in the shaft. When I put the short rod in it bottoms out against the nut. Should the short rod stick out a little bit from the nut? I should mention I also have an Ultima open belt primary.
