Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
There were 2 ratchet tops an FX and an FL one is top pull one is bottom pull if you want to change it just go to the opposite one. From the factory they all came with a standard shift pattern if yours is backward then I would say someone changed the shift drum.
