Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Softail Evo Tranny Knock
Old 04-25-2013, 12:05 AM
Murph72's Avatar
Murph72
Murph72 is offline
Stage I
Default Softail Evo Tranny Knock
I own a 93 Softail Evo that I had a clutch installed about 300 miles ago and I have recently developed a knock in fourth gear. I took the top off of the transmission and I can't visibly see anything wrong with it, everything seems to shift fine and everything appears to be in order. I am wondering if maybe I need to adjust the clutch now and would the clutch only effect 4th gear? The knock has a similair sound to what a rod knock in the engine would sound like. If you can help it would be greatly appreciated.
Old 04-25-2013, 04:38 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,465 Likes on 4,598 Posts
You could have a loose compensator nut.
Old 04-25-2013, 07:34 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Gear teeth do not normally knock unless you are missing a tooth. Stock 5 speeds are inherently noisy in 4th but it is usually a whine.
myred55
11-18-2009 10:17 AM
floridaboston
08-09-2009 09:25 PM
ozzie65
11-08-2008 07:47 PM
fiveola
Shovelhead
05-18-2008 01:48 PM
plydon
08-09-2007 08:20 AM
Quick Reply: Softail Evo Tranny Knock
