compensator question
04-26-2013, 09:35 AM
How can you tell when your compensator is starting to go bad ..? Thanks
04-26-2013, 03:04 PM
Noise from the primary would be a good start. Pull it apart and have a looksie.
05-10-2013, 06:36 PM
Mine sounded like I had loose ball bearings in the primary. That was the first hint I got.
05-16-2013, 10:23 PM
Once its apart what are you looking for? Assuming there aren't obvious cracked/broken parts.
05-17-2013, 10:35 AM
Quote:
Originally Posted by
2-Piece
Loose, excessive play or kind of a wobble. Listen for noise as you spin it as well.Pull your plugs before you try to rotate the primary chain.
lowflyer
05-27-2016 05:51 PM
dad311
17
08-30-2013 09:37 PM
arighi
06-04-2013 11:22 AM
drfalken
05-25-2009 09:52 PM
ny06fxdb
05-17-2008 04:15 PM
