Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Should a main shaft bearing be noisey?
Old 05-06-2013, 12:11 AM
Zerk's Avatar
Zerk
Zerk is offline
Default Should a main shaft bearing be noisey?
On a 07 FLHTCU, the bearing for the main shaft in the primary. It seems to turn ok, but it is noisey. It just seems odd to me when I turn a bearing I can hear it. Last time I had it off, I don't remember checking cause that wasn't the problem I was chasing.
Bike has whirring noise, doesn't matter, clutch in or or. I blew out the front brakes, and don't see any think unusual.
I couldn't compress the tensioner, even pushing on it with hammer handle, when on the bike. Maybe 1/6-1/18. Not like how you can compress it on the bench.
I first replaced the front wheel bearing think that may be it. Readjusted belt too.
So should you hear the bearing when you turn it by hand?
Thanks.
Old 05-08-2013, 04:22 PM
djl's Avatar
djl
djl is offline
Received 2,010 Likes on 1,489 Posts
Thanks.
Absolutely not. The auto tensioner has been known to adjust too tight and loading up the bearing you are hearing. Pretty common issue from what I read on the forums. You should definitely replace the bearing and consider replacing the tensioner with the Hayden unit or the new manual H-D adjustor.
Old 05-08-2013, 05:58 PM
Zerk's Avatar
Zerk
Zerk is offline
I got a M6 on order, and I am going to replace the bearing. The HD manual one I say was the SE version, and the pad sure looked small. Probably fine for racing, but not street use, where the miles rack up fast.
1004ron
08-25-2018 11:01 AM
Wi_Duker
02-25-2016 08:17 AM
nevadarider
06-01-2015 02:57 PM
Guntoter
10-20-2010 12:12 PM
Rotti2
02-18-2009 09:00 PM
Quick Reply: Should a main shaft bearing be noisey?
