IDS will it help?
IDS will it help?
I bought a 2007 flht and honestly did not do my homework, but it has a loud chatter in the primary after reading all the posts I realize I probably need the IDS my question is 1: mine makes noise in all gears not just fifth like others I have read about, 2: if I am idling in gear and put it in neutral and let off the clutch the noise is pretty loud I am assuming that is beacause all tension is off the chain and it rattles more freely? Will the IDS help this and will it hurt to ride before i get the fix, and what does the fix cost now? Thanks for your help
starman
11-03-2007 07:35 PM
