not the same old clunk
Ok, yesterday while riding my 08 ultra I noticed a clunk similar to the shifting clunk. The clunking was noticeable crawling at slow speeds in 1-2 gear thru a parking lot. What worried me is that it clunker while my clutch was pulled in. The clutch seems to be doing it's job, I stopped the bike with the clutch, the clunking stopped, when I got up around 10/15 mph I pulled in the clutch and with the clutch engaged while the bike slowed the clunking started again. Very similar to trying to ride in the wrong gear at too slow a speed, if that makes sense. Any ideas?
clunk
How many miles on the bike? Compensator is the most common suspect, followed by the auto tensioner...yours came with the extra crappy style. It could be as simple as the Compensator bolt has loosened up. Doesn't sound like the inner primary bearing as your description is the opposite of what that usually does when its bad. Feeling any extra vibes while riding? Main drive gear bearing is also a possibility....hopefully not that though. Only way to find out is take the primary cover off and take a look...let us know what you find
BuzzCap7
17
05-06-2017 09:21 AM
freebyrd
06-06-2008 09:22 PM
