'03Dyna compensating shaft
I am working on an '03Dyna that had the compensating nut loose. It backed out and the stator and rotor are ruined, but the biggie is the sprocket shaft extension. It was 'fused' on to the motor shaft and had to be cut off. My memory fails me and it need pics of the left side of the motor from the bearing out. I believe I have more material to remove as I think the shaft extension rides against the bearing? The I.P.B. is-not real clear. I think what I am seeing is the sprocketshaft spacer, p/n 24038-03, whick should ride against he bearing and inside the seal. Does anyone have pics that can help me?
