Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Starter Drive Problems- 1979 FLH
Old 05-26-2013, 05:40 PM
benenglish76's Avatar
benenglish76
benenglish76 is offline
Stage II
Default Starter Drive Problems- 1979 FLH
Hi all,
I have a 1979 FLH Shovel, 80 inch. Has anyone experienced problems with their starter drive destroying starter rings? It is a new starter, solenoid and starter ring. I believe all the parts are V-twin aftermarket parts. Thanks in advance. More info can be provided if needed.
-Ben
Old 05-26-2013, 05:55 PM
brownfoxx1's Avatar
brownfoxx1
brownfoxx1 is offline
what happens when you try to start the bike?is the starter over-running? not dis-engageing?alignment problems? is the solenoid sticking? maybe mis-aligned ring> all these are questions, thought items.i have a '79 FXEF that starts with a turn of the key. not bragging here,and had a '74 FXE with no problems. just to show that it is possible for the starting system to operate normally. lb
when did the problem start?
Old 05-27-2013, 08:51 AM
benenglish76
Stage II
The bike will turn over. It would appear to be alignment problem, the starter gear is making a horrendous grinding against the ring, slipping. could it be any difference that the primary cover is an aftermarket part (common problem perhaps?) I was told that the cover, if not machined right, can cause some major problems. Thanks!
Old 05-27-2013, 11:06 AM
ROTTEN ROB's Avatar
ROTTEN ROB
ROTTEN ROB is offline
+1 on the aftermarket cover, on some the tabs and holes are off as well as not being machined flat.In turn pinching and throwing everything off......
Bagger G
Shovelhead
01-24-2018 10:10 PM
Vulcun
05-21-2011 09:08 AM
Vulcun
05-20-2011 10:40 PM
Delawaredave
10-26-2009 06:58 AM
msgtarmor
Shovelhead
10-14-2008 10:31 PM
Quick Reply: Starter Drive Problems- 1979 FLH
