Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
transmission fluid change problem 99 dyna
Old 05-28-2013, 08:58 AM
money2burn's Avatar
money2burn
money2burn is offline
Stage I
Default transmission fluid change problem 99 dyna
I was changing the trans fluid. I took the plug out to drain old fluid and there is now a spring sticking out the drain hole. What is this spring and how do I get it back in so I can return the bolt and fill with new fluid. As well the spring in question looks like it my have over extended when pulling the bolt out?
Old 05-28-2013, 11:28 PM
cnntnsxty's Avatar
cnntnsxty
cnntnsxty is offline
6th Gear
There shouldn't be any spring sticking out. Have you been having trouble shifting? I havent been in one for awhile but I remember there is a spring on the shift shaft and there is a detent spring but no spring should come out with the plug. Sure it isn't a piece of a spring?
Old 05-29-2013, 08:04 AM
Danofxdx's Avatar
Danofxdx
Danofxdx is offline
could it be a Helicoil for the threads? not sure if they were used in the factory or maybe someone repaired the threads. only one spring that I see in my manual and it is for the baffle and it looks to big to fit through the drain hole.
Joboo1966
03-28-2014 01:13 PM
LDB187
04-09-2011 09:10 PM
brgtr3
Oil Archive (no new posts)
11-17-2010 06:37 AM
maxwhoo
05-02-2008 06:10 PM
hdjoe88
11-16-2006 10:54 PM
Quick Reply: transmission fluid change problem 99 dyna
