SE 37951-98 HD clutch spring
Howdy all,
Have ordered the above spring to help fix clutch slippage after cams and big bore to my bike, I'm assuming (hoping) it comes with install instructions, meanwhile I'm just looking through my workshop manual wondering where exactly it fits in with the existing clutch components?
I guess it just replaces the stock diaphragm spring. I thought it might have been used in conjunction with it.
You can also install the H-D "easy pull" ramp. You didn't say what year but if an early model with the older cables that don't have the teflon lining, upgrading to a later cable will help with the pull as well.
billablehours
01-18-2016 09:13 AM
