2009 electra-glide gearing change
Hi, I have the 2011 30 tooth tri-glide front sprocket installed with a 139 tooth
gates belt on my stock rear sprocket bike. Well, I had noticed the belt was loose, (1'-1 1/2") and didn't adjust it. It broke, my fault, will order another one. In the mean time, my question is, could I convert the rear sprocket and belt from the tri-glide to my 2009 electra-glide, so I will get the Harley 1 1/8" 139 tooth belt? Always like a plan B. Thanks.
HDCrossbones09
01-15-2013 06:00 PM
