What's different.
The case is different and so is the shift drum and neutral switch location. Check this out:
http://bakerdrivetrain.com/wp-conten...-case-pics.pdf
The neutral switch is normally closed in the 99 and normally open in the 06. The actual position of the switch in the top cover is moved about .020 inches to the left.
