Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
starter pinion gear
Old 06-21-2013, 12:57 PM
lunyty1's Avatar
lunyty1
lunyty1 is offline
Default starter pinion gear
i have a 88 flhs ,the starter was screeching so i took it apart,,looks like the starter shaft is turning but not gear,,i tried to pull the shaft out but it won't squeeze past the clutch basket,,will the nut on the end of the shaft come off ? ,i cant seem to get it loose,,and i hate to pull the baske ,chain,and comp to change the gear...is the gear on the "88 bagger "have any thing that can go bad other than the teeth ???
Old 06-21-2013, 09:54 PM
ajayrk's Avatar
ajayrk
ajayrk is offline
I think that nut has a left hand thread.
The pinion gear also is the over runing clutch.
http://www.bikebandit.com/assets/sch.../HD0865044.gif
Old 06-21-2013, 10:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,467 Likes on 4,598 Posts
The nut is left hand thread.
The pinion gear also has an internal clutch mechanism, that is usually what fails, allowing the starter motor to spin, but the gear itself does not turn.
Be careful, make sure the battery is disconnected before you do anything with that pinion gear.
If you pull on the pinion gear it will cause the contacts in the solenoid to come together, and the motor will be energized, even if the ignition switch is off.
You can remove the clutch,primary chain and compensator to gain room to pull out the pinion gear, or you can remove the starter and housing.
Don`t use an el-cheapo aftermarket part, get one from the dealer.
Old 06-21-2013, 10:43 PM
lunyty1's Avatar
lunyty1
lunyty1 is offline
thanks guys,got the nut off finally ,,ordered the new bendix,thanks for your help ,i've rode and worked on harleys for 30 years and never had to replace the gear,,guess i was just lucky..
scot210
05-29-2014 10:08 PM
cajun1957a
Shovelhead
01-02-2014 11:45 AM
Jackie Paper
12-15-2011 01:16 PM
ConRic72
05-15-2010 09:18 AM
Iron Joker
Ironhead
03-19-2010 07:08 PM
Quick Reply: starter pinion gear
