transmission leak
transmission leak
Got a 95 flstn and I developed a leak from the inner primary which came on within minutes. I was somewhat familiar with a root cause seeing how it was gear lube, and assumed it was a bad oil seal(s) in unison with the mainshaft bearing. After digging in, the seal was bone dry. The mainshaft nut was worn, so I replaced that as well as all seals/gaskets to this point and leak remains. It seems to be seeping inside and around the shaft nut. Possible race issue?
eddbenson
06-19-2012 12:42 PM
