oil leaks from primary when ideling
Sounds like the inner primary bearing seal leaking to me. I had same symptoms on my '04 Dyna. Course, by time I got stopped & noticed the trail of primary lube behind me, the lube was nearly all gone. Your primary bearing race may have walked inboard, opening a gap between main shaft & seal. Sounds like primary tear-down time.
Ndoggct
08-31-2015 08:32 AM
Oilslick
11-29-2006 11:38 AM
