compensator
compensator
Hi ,
I have a decent build, shown in my sig, I found my clutch was slipping so I added a Barnett HD spring, now that that is all good, I was hearing this clang noise coming from the compensator area. I had it all apart today, found red stator plastic stuff from last year when I (big mistake) let HD change mine out cleaned it out, torqued to max spec ( 165 lbft). if the clanging continues, can there be something wrong with the compensator? The bike has 52k miles and I don't baby her one bit. Would the screaming eagle compensator be a good move, do I even need a new one?
While I had it apart I noticed a shiny drag mark where the compensator travels.
PS to any moderators I tried this in the tranny, clutch, driveline section and got very little feedback at all.
It actually started last year as soon as I slapped the power vision on there, it was a 103 at the time. I used to run a PC-V but the I noticed right off first ride around the corner PV is so much more responsive I guess the compensator couldn't keep up and the clang noise started right then. I was in denial!
I'm worried now the ipb may have been getting the shock from this. Should I be or is the IPB not really involved. time will tell but if Im in there I may want to do it right away.
The comp beats the crap out of IPB's and starter clutches. Unfortunately there is no aftermarket 1 piece IBP for the 08 primary. If you get a can of rocks noise tha is affected by clutch engagement then start sourcing parts. Some have also experienced a primary chain being over tightened by the auto adjuster. Mine is fine after 120k though. The Baker unit is prolly the best alternative. DH is supposed to release the new comp in early July. Im on the waiting list for one as well. My SE come has neer 70k on it and is worn out.
SavageChopper
07-31-2019 07:58 PM
