Adjusting clutch
Adjusting clutch
Iv noticed on my 2011 wide glide that when the bike is in gear,engine off and i pull the clutch lever in, the bike will not roll, and its hard to start in gear with the clutch lever pulled in.Im thinking that this isnt right.Seams to me i should beale to roll the bike in gear with the lever pulled in.
The bike shifts fine and the clutch isnt slipping. Any ideas?
Your bike has a wet clutch, and even though you pull in the lever, there is drag and suction between the friction plates and disks.
