Shifter linkage adjustment problem
I need help. Because of a breakdown on the road, being unable to procure exact replacement parts, etc. I am not able to determine what my shifter linkage assembly's original length was. So I do not have the opportunity to match up the new part's length with the old part's length. I am having difficulty getting this adjusted properly so that I have use of all 5 gears. To say this is frustrating is an understatement. Does anyone have a process or procedure to adjust the linkage? There was nothing wrong with this until the stock ball joint broke off at the point of attachment to the shifter foot lever.
