6 speed shifter shaft bushing
I just sold an 03 RK that didn't leak a drop and bought an 09 Ultraclassic that leaks everywhere. I just changed trans mainshaft seal, shifter shaft seal and inner primary seal. shifter shaft bushing seemed to have alot of play but local indy said "they're all that way". After 100 miles shifter seal is leaking again. Has anyone had to change that bushing before? I used RTV on the OD of the seal but it is leaking as bad as before. Trans vent seems to be clear...
Any help would be appreciated!
