2011 dyna primary fluid change
I drained my primary and removed the cover with the 5 torx screws - in between the cover and motor was a flimsy plastic circle ( like a cd ) with a flat/thin rubber gasket.
My bike is a 2011 and according to manual I should be using a rubber ring gasket with "nubs" on it. That's what I got from dealer- so I'm confused here - hoping for some clarification.
Thanks!
Thanks!
