New clutch won't disengage
I recently had a Screamin Eagle clutch installed. I took the clutch basket to the dealer and they put the clutch in. I got it home and put it all back together. Now it won't fully release. When I'm sitting at a stop in 1st gear, the bike is moving forward. It is really hard to downshift at slow speeds and it is almost impossible to get into neutral. Plus when it is in 1st gear I can not shift to 2nd unless the bike is moving
I did the adjustment exactly how the sticky thread said to do it. I did the screw first then the bolt adjustment. I just did the adjustment again this morning and went out for a ride. It is still doing the same thing I described. When I shut it off and try to push the bike in gear with the clutch pulled in, it won't move. I put it up on the jack and the wheel spins unless it's in neutral. When I put it in gear and pull the clutch the wheel still spins
2003 883r Sportster
2003 883r Sportster
BuzzCap7
17
05-06-2017 09:21 AM
travalab
06-28-2013 01:01 PM
