Motor to
Motor to
I'm looking for the 2 dowel pins that press into the lower front mounting holes of the transmission ...... engine to tranny alignment pins Not sure if they're roll pins or not, but need a couple, would anyone have a source to make a purchase or even an HD part # would greatly be appreciated - THANKS
Mark - 05 tc88. This was a bare case I picked up that needed some repair. Also looking for all other roll pins and dowels that need to be implemented to the tranny case! At least 1 inner primary dowel, either 1 or 2 dowels for the trap door, 4 roll pins for the drum pillows, top cover pins if applicable and 1 shifter shaft bushing, not sure if there's a bushing for the starter pilot hole - Thanks very much for the reply!!! appreciate it
Case to motor is a 16574-99a
pillow blocks 609b
The rest of them I would have to look up or you can give me a call and I'll get them coming to you.
We use some Harley part numbers and some come from our suppliers like the 2 door pins. One is solid 26768 and the other is a split pin 64273.
pillow blocks 609b
