Sportster Front Pulley Stripping
Hey
Got a 2006 1200 Roadster that is eating up front pulleys. Replaced the pulley last Sep, when I got it off the inner splines were stripped, looked like a mill had been taken to it. Replaced it with OEM pulley. Wednesday morning riding to work and it happened again, took off at the light and Bike started whining/grinding noise, wouldn't go for nothing, I worked the gears no problem, so I'm fairly confident its the pulley again. Going to check it out tomorrow evening. First, checking if anyone has experienced something similar, second anyone got any ideas or advice as to what might be causing the pulley to strip like this?
The Bike has a Stage 1 and 2 kit fitted for what's it worth, but shouldn't make a difference
Any info is appreciated.
Cheers
Cheers
Jumpman
08-23-2013 03:29 AM
ozzie65
01-23-2009 03:15 PM
