Clutch Question
Clutch Question
On a 103 engine, what stops transmission oil from flowing up the clutch cable. I get that there is an O ring seal that stops the oil from leaking out AROUND the clutch cable, where it enters the cover, but what is there to stop oil from getting actually into the cable between the inner and outer cable parts??
There may be an obvious answer, if so please indulge me..........I might be having a stoopid day!
Is the area behind the clutch cover running with fluid, as it seems to be above the maximum level, if so why drain the fluid before removing the cover???
Ride your bike up on a 2 x 8. Lean it on the stand and the oil will move to the lower side.
You then can remove the cover without draining the transmission. A small amount of residual oil may drip out. And you may have to remove the exhaust to get to the cover.
Basically gravity and the transmission vent keeps the oil out of the cable.
n0code
09-02-2010 11:47 PM
