Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
If you mean the main case bearing that the 6th gear rides in, then the answer is yes it's common. The question you need to ask yourself is how many times do you want to replace it.
