Inner primary swap
I have replaced the starter with an All ***** 1.4 kw, replaced batt., solenoid and cables. Checked for proper grounding, and still it barely turns over unless I leave out the solenoid return spring.
I finally sent it to the best wrench in the area, and after he replaced bearings, seals and plunger, and tried every trick he knew, he finally gave up.
Trace the wires from terminals 87 and 30 on the relay, make sure they are in good condition, and connections are clean and secure (the juice passing through these wires is what controls the movement of the solenoid).
