Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Anyone on here running the Exile Open Primary? If so, bout how big of a job would it be to tear it down to PC the front cover n rear sprocket cover black?
Not sure, but if it gets too much you can just send the primary to me
Seriously though I like blacked out bikes but yours would be perfect with just the trees and maybe the front belt cover in black. I'm really digging the current mix of black purple and bare metal finish
If you want the whole thing black, then everything has to be removed. If you just want the front cover, rings, and rear plate cover black then it's not too bad. Look up a Primo install sheet on the internet and that should give you a pretty good idea of what is involved.
