Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have no trouble using my frotn brake. But my clutch is both hard to pull and it seems the travel squeeze of the clutch lever pull is farther that brake lever.
Anyone know of a way to make the clutch lever pull easier and shorter distance?
Your clutch lever will probably squeeze all the way to the grip, but the brake lever won't, nor should it. There is not much you can do to alter the way the clutch lever functions, however there are various ways you can reduce the effort you need to squeeze it. What year is your bike?
