Jackshaft bolt unscrewing itself
Saw a thread on this from 5 years ago with no final solution, so asking the same question again hopefully someone has a solution for me.
I replaced my starter clutch and properly placed the springs and bearing, tabs are all in place, pulled the starter out and rechecked it 5 or 6 times but the same thing keeps happening when I engage the starter, the jackshaft bolt inside the primary unscrews itself! It's driving me insane. I'm placing the proper torque too. Anybody had this problem and can provide me with a solution?? 2005 Road King, Thanks
You have the small and large couplings installed according to the service manual, all splines properly engaged?
Correct jackshaft bolt, thrust washer and lockplate?
The lockplate goes directly under the bolt head, the thrust washer goes between the lockplate and the jackshaft.
Use a new bolt.
Use a new bolt.
springer96
06-01-2009 05:26 PM
Evilution
04-15-2008 06:39 PM
