Noise from Primary
Noise from Primary
I posted this in Softails but realize now it was probably posted in the wrong area, so I am reposting here.
I have an '07 Deuce and my primary has developed a noise that only happens when having engaged a gear and then put into neutral. I thought it was a case of a loose chain or sorts.
I drained all oils (I had to do a change anyway), adjusted the primary by 2 notches. This gave me a tension of 3/4".
The cover had a wear mark from where the chain was hitting it - near the bottom front.
I dremmeled the wear just enough to smooth it out WITHOUT taking off any excess.
Cover back on, filled with oil, and still a noisy primary - not nearly as much but still there.
I didn't notice any wear on the automatic adjuster.
Is a new adjuster and/or chain needed? although (I would think) it's still early days to be replacing those - approx. 20,000 miles.
Thanks in advance for any help
When I start the bike to go riding - (in neutral while I get my act together) - no noise. Put it in gear, take it out of the garage, put it in neutral to close the garage door etc, noise appears.
I have done exactly that while at a stop light or such and yes, while still in gear and with the clutch lever in, there is no noise.
Wakko47
01-17-2014 12:01 PM
