Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
starting problem
Old 04-15-2014, 03:00 PM
tugboatlife's Avatar
tugboatlife
tugboatlife is offline
5th Gear
Default starting problem
so I got my shovel all put together nowand the starter is screwing up I have a new solenoid and did the test from the manual to make sure it was good everything in place and wired correctly when you hit the start button it will engage the starter but then it disengages before it will turn the motor a full turn checked voltage drop and there is none I have 12.6 v at the little wire on solenoid and at the starter is 12.6 v while holding the button new battery with a slow charge it just won't stay engaged what are my possibilities
Old 04-15-2014, 04:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,499 Likes on 4,612 Posts
Is the drive unit actually backing out of the ring gear?
Or are you assuming this because you can hear the starter spinning but the engine does not crank?
Old 04-15-2014, 05:39 PM
tugboatlife
5th Gear
yes it does actually engage because it turns the motor about a half turn then it popes out
Old 04-15-2014, 05:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
When the starter disengages, does the starter motor keep spinning?
Old 04-15-2014, 05:56 PM
tugboatlife
5th Gear
yes it does
Old 04-15-2014, 06:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I think the starter drive unit is shot...
Item 12 in the illustration:
http://www.granitestateharleystore.c...-10274-H080063
aces101
Shovelhead
23
07-09-2012 09:02 PM
89 FXRS
EVO
06-17-2012 04:16 PM
Jinxie
10-25-2009 10:19 PM
shorster
Ironhead
06-14-2009 08:29 PM
chriscresw
Classic
10-11-2005 11:13 AM
Quick Reply: starting problem
