Questions regarding transmission
I have a '77 Shovelhead with a 4 speed transmission. It was stuck in second gear so we took out the trans to inspect. I can easily move the countershaft gears in and out of the main gears however when I do and try to turn the main shaft the gears lock up. Is this supposed to happen? Also, what would I be looking for that would cause it to lock in gear?
Ccr71
04-11-2017 04:29 PM
