Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
EVO 1340 - front and rear sprocket
Old 04-17-2014, 05:55 PM
dawroz's Avatar
dawroz
dawroz is offline
Default EVO 1340 - front and rear sprocket
Hallo friends.
I have a new problem with my EVO 1340 with chain (no belt).
I have to match my front sprocket with my rear sprocket (51 teeth).
How many teeth is the most universal sollution (22,23,24) ?
Old 04-18-2014, 10:24 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Originally Posted by dawroz
Hallo friends.
Was your Stock setup a 32/ 70 if so then that was a 2.18
A 23/51 would be a 2.21 which is your closest option
A 24/51 would be a 2.12 which is a little taller which means not as much torque pulling away from a stop but lower rpm's on the highway.
Old 04-18-2014, 03:31 PM
dawroz's Avatar
dawroz
dawroz is offline
OK. Thanks. I will test it - 23 x 51
I will write soon.
Old 04-19-2014, 10:27 AM
DonM's Avatar
DonM
DonM is offline
I will write soon.
Maybe it was the wrong way to do it, but I changed the rear sprocker by 2 teeth. I unfortunately don't remember the rpm before, but the after is 3000 rpm at 70 mph.
OOps! sorry. My bike probably doesn't apply. I still have the 4 spd tranny.
cowboy 51
EVO
25
11-23-2013 05:34 AM
riderboy1961
08-20-2013 11:05 PM
hov2
Shovelhead
11-27-2012 11:34 AM
Greabert
06-06-2011 10:33 AM
Scarletthehog
Ironhead
17
04-19-2008 07:27 AM
Quick Reply: EVO 1340 - front and rear sprocket
