Clutch or Need Adjusting?
It has been a LONG time since I have posted here, but as soon as I had a problem, this is naturally where I come for help...I tried searching this, but could not quite get what I needed.
I have a '12 Fat Boy Lo with 1300 miles on it...Sunday afternoon I met some friends in an empty parking lot to show them 'counter steer, head/eye position, clutch/break for tight turns' etc.
During that time, I think I overheated my clutch...When I went to leave, I noticed my clutch lever was almost fully extended before the clutch would engage.
I know this info is slim, but off the top of your head, do you think I can adjust the cable or have I burnt the clutch up?
http://www.roadglide.org/showpost.ph...68&postcount=5
Start here and if this doesn't do it....well...you know! Good luck!
Thanks brother...I will do that.
I have used this very simple method 4 times on 4 bikes and it works well...once you get the hang of it....it's a feel thing but not tough to do. If you don't trust me or this method, then so be it. Best of luck to you...I'll give you the link again in case you want it. Oh and like it says...do it cold.
Smoothie54
05-04-2018 02:30 PM
