Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Dropped a screw into Transmission... uh oh
Old 04-24-2014, 06:25 PM
FoxyRoxy23's Avatar
FoxyRoxy23
FoxyRoxy23 is offline
6th Gear
Default Dropped a screw into Transmission... uh oh
Don't yell at me guys, I did a search first and I did find similar threads, but my question is a bit more specific.
The story is that we've dropped a screw into the transmission of our 2014 Street Glide S. We know that it's in there because we watched it actually fall in there (the top cover was off) but we can't fish it out no matter what. We've tried all kinds of tools, magnets, grabbers... nothing's worked. Transmission is wet, so a vacuum won't work.
We do all our own wrenching but we've never tackled a transmission before. Can anybody tell me the easiest way to get into it to fish the screw out? We will go buy the appropriate manuals and figure it out from there, but just looking for someone to say: "remove the XYZ" so we can educate ourselves and do it. Any help would be awesome. Should we try to move the bike? Move it side to side or will that make it worse?
Having a downed bike when the weather is beautiful is truly awful. Thanks in advance!
Old 04-24-2014, 08:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,497 Likes on 4,612 Posts
Can you see the screw? You need to get the screw out with out disassembling the transmission. Unless you are ready to kiss the warranty goodbye...
Gotta ask, why did you remove the top cover from a transmission that is under warranty in the first place?
Old 04-24-2014, 08:48 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
You can try this:
http://www.google.com/url?sa=t&rct=j...bGZq8M6eB1gHqw
Use a small dental mirror to look for it.
FoxyRoxy23's Avatar
FoxyRoxy23
6th Gear
GOOD NEWS! We finally fished it out. Taking a two hour break from it to cool off seemed to help. Dan89FLSTC, we were installing a wrinkle black powder coated cover. Thanks for the response; we were thinking of disassembly as a last resort, but after trying for several hours to get the screw out, we were starting to think it would be the only way. Thanks though!
Old 04-25-2014, 04:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Thanks for the explanation, and the follow up.
Glad you got it out.
Old 04-30-2014, 08:42 AM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,482 Likes on 1,541 Posts
if you are in a tight spot sometimes you can wrap a wire around a coat hanger and put a small battery to it to magnatize it and use this to get ahold of something.
springer 03
07-21-2014 06:13 AM
motoxraca33
02-09-2013 04:46 PM
JPL
03-30-2011 09:29 AM
bboeye
04-13-2008 09:11 PM
hdpearson13
Ironhead
12-07-2007 08:41 PM
Quick Reply: Dropped a screw into Transmission... uh oh
