clutch or trans
clutch or trans
I adjusted the clutch per service manual on my 96 cubic inch 07 Road Glide with a six speed trans, clutch still slips in 3rd gear replaced clutch plates, steals & diaphragm spring and clutch clutch still slips in 3rd gear, I think the problem is in the trans, no problems in any other gear,Any pointers, suggestions, solutions would be appreciated I'm @ my wits end thnx
I was looking at clutch adjustment myself...
This was offered as a solution:
http://www.roadglide.org/showpost.ph...68&postcount=5
There is also a Stick at the beginning of this forum.
If you're running basically stock or stage 1, your stock clutch should work no problem. I had to upgrade my clutch with motor work.
The Transmission doesn't seem that likely. I'd consider that a warranty issue if so.
Good luck.
Good luck.
If something is slipping, it is the clutch.
There is something wrong with your clutch, nothing wrong with your trans. The next step IMHO is to dismantle the clutch and clutch operating mechanism, to see if there is something obvious. If you really are at your wits end then visit a dealer or indy. Don't sit out the riding season just because you can't solve a problem - get help!
MURPHCC1
09-04-2015 09:34 AM
