1986 FXR does it need adjustment?
I got a new rivera clutch installed, last week my relay went out but when I got on my bike I noticed that it will not roll in neutral or in gear with clutched engage, I heard things from it needs adjusting, its normal since its a new clutch and needs to break in, its cold, etc, etc. if I could get some clarification id really appreciate it thanks!
It doesn't matter if the clutch is engaged or disengaged the bike should roll if it's in neutral. The only thing I can come up with, is the trans actually in neutral. Jack the rear wheel clear of the ground, shift to the suspected neutral position, then attempt to turn the tire. If it won't turn, shift up and down while turning the tire. If the tire turns freely at any point, that's neutral. If it still won't turn, it's likely the ratchet needs attention/adjustment.
That's the best I can come up with. Good Luck!
So just loosen cable, remove cover, loosen locknut, back out back in adjuster till it's tight half step back tighten locknut than adjust cable?
Talldog
07-20-2014 11:17 PM
cbaker1@farmersagent.com
05-16-2011 02:11 PM
