Road Glide Clutch Pack
I found my stator had gone bad and found a lot of metal pieces on it. I checked around in the primary case for the source of the metal. Turned out to be this.
this is the back side of the clutch pack bearing where the mainshaft enters it. This is right about at the point where the mainshaft splines taper up to the smooth surface of the mainshaft before the mainshaft bearing in the primary. I'm not sure if this part of the clutch pack bearing splines are being crushed by the tapered spline groves or if something else is happening. I did remove the bearing retainer clip before taking this picture.
My question is: what would be causing this to occure?
The clutch nut was torqued to spec and the clutch bowl spins freely. I took the clutch plates out to clean them and the bearing still spins freely with no rattle to it. The splines on the mainshaft are clean and in spotless condition.
There was quite a bit of metal bits on the stator but only on the top armatur on the back side against the crank case wall. This stuff was packed on there and wouldn't just wipe off. I had to use a tool to chip it off. Kinda puzzling. The stator is grounded so I have to get a new one.
the stator for sure. Replace the bearing. I think the clutch hub is ok. Didn't see any problems with it. Will have to wash out the primary of all the metal.
My Service Manual makes it look like those chipped splines are part of the clutch hub, what part is it that you replace to get new splines? Just trying to learn, thanks for all the pics.
I also have a new upgrade stator on order from Cycle Electric. Should be in next Wednesday as well. It will take me a couple of days to put it all back together for a ride on Saturday.
