Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Trany mainshaft runout question
Old 05-04-2014, 07:43 PM
danoflhrci's Avatar
danoflhrci
danoflhrci is offline
Default Trany mainshaft runout question
Just replaced all the seals, race & primary bearing on a 5 speed trany. Really bummed to find these runout #'s.
In front of the mainshaft 5th gear seal; just over .001
Outer end of the primary bearing race; just over .002
Way out between the end of the splines and just before the clutch basket nut threads; .0065
I'm at a lose weather to continue assembly.? Really don't like the thought of the race spinning up & down over .002 in the primary bearing and what's the outer clutch basket going to be doing? The SM says mainshaft tolerances are .003, but it doesn't say where it should be measured.
Should also mention I was always chasing a mild ghost vibration on this bike.
Old 05-07-2014, 07:08 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Is this on a Evo?
Old 05-07-2014, 10:15 PM
danoflhrci's Avatar
danoflhrci
TwinCam. Following advice on another forum I pulled the shaft & handed it to a machinist. It's out .0027 but still within Harleys specs so I think I'm going to run it with a recommended Jims rebuild kit.
Old 05-07-2014, 10:32 PM
soft 02's Avatar
soft 02
soft 02 is offline
Sounds good. I just replaced my input shaft and re built everything in mine. Smooth as silk now.
Old 05-08-2014, 10:07 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
I thought I seen this on another forum. Glad you took to a machinist that's the only way to know for sure.
voodoodrug
01-11-2019 02:51 PM
Jay Guild
05-03-2018 10:45 AM
Jay Guild
05-02-2018 05:25 PM
hell hound
59
03-07-2014 03:30 PM
Tahoe
01-25-2006 03:43 AM
Quick Reply: Trany mainshaft runout question
